Previous in Forum: Semiconductor Singulation (Dicing)   Next in Forum: Leakproof Envelope Around Pipe Having High Pressure Ammonia
Pipe Body Weight Calculation.
05/27/2009 12:25 AM
How To Calculate The Body Weight Of A Carbon Steel Pipe ?.
Re: Pipe Body Weight Calculation.
05/27/2009 3:18 AM
  1. Weigh an offcut.
  2. Measure the length.
  3. Pro-rata to the length of the pipe in question.
06/03/2009 4:15 AM
Dear Mr.!
1. Estimate weight of pipe in metric tons per kilometer:
To estimate the weight of pipe in metric tons/kilometer, multiply the nominal diameter by the number of sixteenths of an inch in wall thickness.
Example. Find the weight of pipe in metric tons/km for 20-inch dia pipe, wall thickness 1/4 inch
4x20 = 80 tons (metric) per kilometer.
The actual answer from pipe table is 79 metric tons/km.
This common rule is based on a density of 900 pounds per cubic foot for steel. For larger diameter thin wall pipe, this approximation gives an answer usually 01 % low. The accompanying table gives a comparison between actual weights in metric tons/km, as compared to that calculated by this rule
2. Pipe weight from OD and wall thickness:
Weight (pounds per foot) = Dt - t2x10.68 (note: t2 is square t)
where D = OD, inch
t = WT, inch
the above equation is based on a density of 490 pounds per cubic foot for steel. High-yield-point, thin wall pipe may run slightly heavier than indicated.
There is another equation for calculation but a bit more complicate with material tolerance, relative weight factor. If needed, i could show you later. Hope it could help you in calculation especially for quick calculation onsite.
Regards
Howard
There's nothing difficult, just afraid not much money. Mountain cutting and Ocean backfilling, if couldn't, so hire
