Previous in Forum: Correlation between ANSI class and PSI rating?   Next in Forum: Squre Threaded Bolt Design
Jacket Bursting Pessure (Pressure Vessels)
05/27/2009 11:12 AM
How to calculate jacket Bursting pressure?
Re: Jacket Bursting Pessure (Pressure Vessels)
05/27/2009 11:22 AM
Well, I'd take a theoretical section through the jacket, along several planes, and do a force balance calculation.
Good moaning!
Good Answers: 183
05/28/2009 4:28 AM
First step compute the stress values in axial and tangential directions, second step compute the equivalent von Mises stress and if this has a value over the elasticity limit of considered material then the risk for bursting is real. How much the pressure has to grow further for burst depends on the evolution between yield and ultimate stress for the material.
If the wall to radius ratio is small you can use the force balance recommandation, if the wall is thick use the Lammé equations which give a better result.
Re: Jacket Bursting Pressure (Pressure Vessels)
06/19/2011 8:41 AM
Where do I get the procedure?
Register to Reply 3 comments
Crabtree (1); nbhide108 (1); nick name (1)
