Previous in Forum: Combustion of Organic Compounds   Next in Forum: Diaphragm or Piston Actuator Flow Control Valve
Pipe Thickness
05/27/2009 6:04 PM
I want to calculate a pipe subject to external pressure AND a compression force applied to the ends.
Good Answers: 51
Re: How do I calculate the thickness of a pipe subject to external P and compression
05/27/2009 7:46 PM
Do you need to design to a pressure code?
A little knowledge is a dangerous thing.
05/28/2009 3:28 AM
If there is no pressure code to design to, then carry out a theoretical slice through the pipe in several planes, and do a force balance. Keep the calculations lest they need to be scrutinised for burst and collapse indemnity insurance reasons.
Good Answers: 183
05/28/2009 4:54 AM
In your case the problem is the loss of stability not only the "resistance".
For the axial force you should consider the pipe as a column and verify depending on the conditions at the ends how big can be the force before collapsing.
For the wall the problem is similar but on an other scale, the wall will collapse if the stress reaches the elasticity limit so that a "hinge" can build up. You may look at the colapse loads for rings or use the simplifed equation σ= pext*dext/(2* t) = Re.
t is the wall thickness. In stability computing the safety coefficents have to be important since there are several variable parameters as thickness, Re and manufacturing deviations.
Hope it will help.
nick name (1); PWSlack (1); XMech (1)
