Previous in Forum: Engineering Mechanics   Next in Forum: Threaded Inserts for Small Sailboat Restoration
MAP vs. MAWP
05/28/2009 8:33 AM
Good Evening to All according to my point of view MAWP-It Is the maximum allowable pressure for given design temperature at top of vessel in normal operating condition i would like to clear my doubt that will i use nominal thikness while calculating MAWP or nomonal thikness less corrosion allowance????? tell me wat abt MAP
Re: Differene b/w MAP & MAWP
05/28/2009 9:24 AM
Always use nominal thickness less corrosion allowance. The vessel still needs to be safe at the design pressure, at the end of its economic life.
05/29/2009 12:27 AM
thank you for reply.... what about MAP calculation shall we use nomonal thiknessk less corrosion allowance while calculating MAP?????
Re: MAP vs. MAWP
05/28/2009 2:35 PM
Search this site for extensive previous discussions.
Anonymous Poster (1); PWSlack (1); sandeeppandey0789 (1)
