Acetylene cylinders must not be used at pressures below 3.5 bar g (50 psi g) (Cylinder Internal Pressure). This is to prevent the discharge of Acetone.
CAUTION: WITHOUT THE PRESENCE OF ACETONE, ACETYLENE IN ITS CYLINDER WILL BECOME UNSTABLE AND MAY EXPLODE.
The above is an extract from a Project specification.
Does any welder/fitter check the pressure of the Acetylene cylinder for the minimum pressure................?
I think that that minimum pressure is automatically maintained by the cylinder by some system.....................such a system will not allow the acetylene cylinder to release the pressure below said 3.5 barg…………….........
Please help me with your advice…..
