That said, you might need to provide a bit more information to get a reasonable response. What hardware are you using? is this planned to be in a PLC? Do you have the PWM? do you plan to build from scratch? Are you simply looking for someone to write the code?
well, apparently I'm no help at all.
Re: Motor Speed Control with FPGA and Optical Sensor
05/29/2009 7:02 PM
Why an FPGA? Nothing happens in any 'ordinary' kind of motor* that needs that kind of speed. What rpm are you working with? A simple micro with built-in RAM & EPROM could do most motor control apps standing on its head - and it would be a lot more flexible. Are you familiar with PICs?
Can you program in BASIC or C (or, perchance, assembly language)? Is this a hobby or one-off on-the-cheap/in-house use/educational project?**
What provides your setpoint for the speed? What kind of optical sensor are you using? Please give some more information.
* This is perhaps excluding 100,000+ rpm ultra-high-speed motors.
** If you've answered 'no' to both of these, you're probably in the wrong job.
06/01/2009 1:46 PM
I feel that you don't know exactly what a FPGA is. It is a large scale integration of logic circuits that can be programmed once or more times, according to a schematic diagram or a language (VHDL) that puts in words the above mentioned schematic. It is used for situations in which you have a lot of logic inputs and outputs. The FPGA itself doesn't have the possibility to run a program as a microprocessor or a microcontroller do. There is possible to have a microcontroller embedded, which would rise the price of an FPGA.
Unless you have to control an Airbus A330-200, you better use a microcontroller, as JohnDG advised you.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
