Previous in Forum: Motor Speed Control with FPGA and Optical Sensor   Next in Forum: about reactive power on synchronous generators
10 comments
Query
05/29/2009 4:12 PM
Trying to get my head round this. Lets take a 240V single phase supply powering a 60 watt light. If I take an amp-probe and clamp it round the phase conductor I will obtain the current flowing in the circuit. This said current is then flowing through the element of the light and back through the neutral to complete the circuit.
If this current is flowing through the element why if I put my amp-probe on the neutral wire can't I measure the current flowing back through the neutral. where does it go?
Thanks
Re: Query
05/29/2009 4:27 PM
If you clamp it around only the neutral you should read the same amperage. If you clamp around the phase conductor and the neutral at the same time you will read zero.
Re: Query
05/29/2009 9:10 PM
If you clamp it around the neutral conductor, you will get no reading. When the current from the phase conductor flowing through the element of the bulb and because of the resistance in the element, the current will be restricted by the element resistance and causes the element to generate heat. The heat is then converted in to light. All the current will be used up by the element. That why, the neutral conductor will be zero.
You will not able to get any current at the neutral conductor.
Good Answers: 103
Re: Query
05/29/2009 9:21 PM
Are we missing Kirchoff's current law?
The Post #1 is correct, the phase current and the neutral current will be equal in a single phase circuit. (the same is not true for a multiphase circuit of course)
Unless some one has connected the load across phase and earth of course (and you don't have the Earth fault MCB at your home switchboard)
Good Answers: 140
Re: Query
05/29/2009 11:35 PM
Simon... current flows from the source to the load then from the load back to the source. Current is not consumed.
Re: Query
06/01/2009 4:37 AM
So, why does the lamp go out when the neutral conductor is disconnected from the supply, then?
Good Answers: 140
Re: Query
05/29/2009 11:46 PM
How many conductors run to your 240 volt light? Three or four? What is the nature of the system? Is it a standard American/Canadian 120/240 volt single phase 3 wire consumer service?
If the system is a standard 120/240 volt 3 wire service, you should have two hot conductors, lets call them L1 & L2, and a bonding conductor going to your lamp. In this setup, there is no neutral connected to the lamp. Current on L1 & L2 should equal each other as current flows from the system source to a load then from the load back to the source.
Please describe the system type and the number of conductors going to the lamp.
Good Answers: 19
Re: Query
05/30/2009 12:06 AM
What ever may be system, the tong tester or ammeter connected to any one side of the device( source side,return side) should show the same current.
Ramesh,Freelance Electrical/automation Consultant
Good Answers: 140
Re: Query
05/30/2009 10:15 AM
Obviously...
I asked for the nature of the system to try and reason why he sees no current on the "neutral". About the only way it make sense is if, there are four wires going to the light, two hots - a neutral (that is not used) - and a bond wire.
Good Answers: 12
Re: Query
05/30/2009 4:00 PM
measured current will not change , may you measured volt ?
if it's so, it will gave zero reading for neutral.
don't tell me who are you , what do you know is enough.
Re: Query
06/01/2009 4:39 AM
One of the possibilities that there is no current in the neutral conductor is that the return path in the posted case is via the earth conductor. Never do this! The earth conductor is there for personal safety and should never carry current except under fault conditions while the circuit protective device operates.
khairy Aish (1); North of 60 (3); PWSlack (2); ramvinod (1); sb (1); Simon Wan (1); wareagle (1)
