Previous in Forum: interpretation of asme b31.3 341.3.4   Next in Forum: Union & reduce coupling
Conversion of synthetic gas volume to weight
05/30/2009 3:07 PM
Dear colleagues,
Iy is known the ultimate analysis of synthetic gas per vol% percentage. ie.
H2:31%
CO:48%
CH4:21%
It is requested the conversion per weight % percentage
Can you provide the methodology?
Thanks
Re: Conversion of synthetic gas volume to weight
05/30/2009 8:26 PM
When is your homework due?
05/30/2009 11:10 PM
M=PV/RT. FOR HYDROGEN IT IS=ATM. PRESSURE*0.31/R*ATM. TEMP. SIMILARLY FOR OTHER GASES , WE CAN CALCULATE WEIGHT OF GIVEN VOLUME AND THEN CONVERT IT TO PERCENTAGE.
05/31/2009 3:40 PM
Thanks Irshad,
But since pressure and temperature remains the same for all gas components, through idea gas equation we end-up the same percentage.
At the end the Mass of H2% is estimated MH2%= 2*VH2% /(2*VH2%+18*VCO2+16*VCH4)
Where 2,18,16 Molecular Weights
Good Answers: 137
06/01/2009 4:41 AM
Hello gvallios
Your equation is nearly there. It should be
MH2%= 2*VH2% /(2*VH2%+28*VCO%+16*VCH4%) Mol. wt. of CO = 28, not 18.
Just need to repeat for the CO and CH4. You seem to have managed OK, what's the problem?
Cheers............Codey
06/01/2009 4:47 PM
Dear Codey,
Thanks for your confirmation on equation correctness
Codemaster (1); gvallios (2); IRSHAD (1); Mikerho (1)
