Previous in Forum: Union & reduce coupling   Next in Forum: Application of Weldolet and Sockolet
rupture disk
05/30/2009 4:33 PM
if high pressure liquid in a pipeline (10") is stepped down by a control valve and the control valve fails open. The potential downstream piping may see the high pressure. Therefore we install a rupture line (4") with a disk. If the disk sees high pressure and breaks then part of the flow is diverted. What confuses me is...when the rupture disk opens and part of the flow is diverted then the velocity in the 10" goes down. Dont we say velocit and pressure and inverse perportion. Then this seems to suggest pressure goes up in 10" line. can anyone help me grasp this?
Re: rupture disk
05/30/2009 7:54 PM
Are you saying that if you have a 10" line with an opened diversion line of 4" purging fluid and the pressure in the 10" line will go up when purge opens?
Definitely no.
Pressure is inverselly proportional to velocity in full developed flows, when all fluid entering one section of pipe goes out from its same pipe section.
What you have is an increase in the area, with the same pressure feeding the line and a restriction downstream that causes the pressure inside the pipe to build up. At some level, the pressure breaks the disk and you have an increase in the exhaust area (the 4" line), for the same inlet pressure. Pressure then drops, because more fluid is coming out of the pipe.
Its not the same pipe area, will not be the same internal pressure. If you'd like to think this way, the fluid velocity upstream of the diversion will increase due to the smaller flow restriction, so, the pressure will drop. The pressure downstream the diversion will drop as a result.
Humm... suspicious you are...
Re: rupture disk
05/30/2009 8:21 PM
As the pressure in the downstream piping increases, the velocity/flowrate decreases. When the rupture disk bursts, the pressure in the downstream piping and the 10" pipe dramatically decreases. Because of this decrease in pressure in the 10" pipe, the liquid's velocity/flowrate increases.
Does that make sense to you?
Mike
