Dear all!
Appreciate if some one could give an advice on this: normally, Isolation Flange (IF) will be installed at the first flange of pipeline connected to metering skid. If i install IF after a emergency shutdown valve just incase of mainternance for IF, i need not to discharge all natural gas in the whole pipeline. Is it any bad impact to the CP system of the pipeline if i install the IF as above or against code/standard. Is there any code/standard, or reference guideline on this? I've read DNV-RP-B401, NACE-RP-0286-2002, and NACE-RP-0169-2002, but not as particular case as this.
Thank you very much for your valuable input.
Howard
There's nothing difficult, just afraid not much money. Mountain cutting and Ocean backfilling, if couldn't, so hire
