Previous in Forum: suspension   Next in Forum: mill tollerence in pipe material?
VRV system ; efficiency
06/02/2009 3:59 AM
how does the VRV system efficient than conventional type A/C units?
Pathfinder Tags: VRV
Re: VRV system ; efficiency
06/02/2009 4:57 AM
It's to do with the motor, not the air conditioning process. The VRV system gives the motors a higher conversion efficiency.
06/02/2009 5:46 AM
Or not, as the case may be.
Anyway. There's a kaleidoscope of information available from that beauty, Miss Google.
06/02/2009 5:08 AM
VRV (Variable refrigerant volume) with individual zone control.Normal air condition for the building as a whole, whereas the VRV system air conditions is for each room individually. It is ideal for the constantly changing occupancy of a typical building. Therefore, each room can have its own control of the air cond temperature that reacts to the exact conditions in each room. Individual control promotes is a far more economical and efficient system for cost saving. Other advantages for VRV System is
  • Saves Energy
  • Precise room temperature control
  • Conserves space
  • Can be installed for each floor
  • Short installation time
  • High reliability
  • LCD remoter controller
06/02/2009 10:24 PM
Thanks,
what are the difference of air conditioning process in VRV unit?
Register to Reply 4 comments
Priyan (1); PWSlack (2); Simon Wan (1)
You might be interested in: HEPA Filters and ULPA Filters, Downdraft Tables
