Previous in Forum: Wobbling Pump   Next in Forum: Plain Bearings Requirements and Tests
8 comments
Good Answers: 53
Elliptical Gears
11/29/2006 5:58 AM
Hi
I am working on elliptical gears operated on axis centre not on focus.
All inputs will be appreciated.ref site show example but focus operated gear.
mathworld.wolfram.com/Ellipse.html
Re: Elliptical Gears
11/29/2006 12:22 PM
Hi Rakesh
You can find a lot about elliptical gears at "Mechanisms and mechanical devices sourcebook" Nicholas P. Chironis, Neil Sclater , Noncircular gears.
Also you can look these links:
http://kmoddl.library.cornell.edu/model.php?m=557
http://www.pbase.com/captain_carl/im...23141/original
regards
lgeo
Buyblueprint.com - Mechanical engineering articles
Good Answers: 53
11/30/2006 8:10 AM
Thank you, for information.
Regards
Rakesh
11/30/2006 7:48 AM
what is the application for elliptical gear?
Good Answers: 53
11/30/2006 8:09 AM
Where ever your need a varying angular speed in each cycle of rotation,
visit to site shown in my 1st post.
02/13/2007 6:53 AM
One good example I can remember is bicycle transmission. Shimano has made a series called biopace, that uses an elliptical gear that has a higher radius in the position aligned to the pedal lever, and a smaller radius in the oposite side, in the position the guy riding the bike is not in the more appropriated position to put force in it.
Simple, but curious in my oppinion.
Humm... suspicious you are...
11/30/2006 9:47 AM
Why must the center of rotation be at the 'origin' or center of the gear?
Is this an absolute necessity? If so the gear profiles will have to be generated for the needed variation in rotational velocity and/or acceleration.
Is this HOMEWORK or CLASSWORK for a machine design class? :-(
12/10/2006 8:27 AM
I actually do have a homework problem for a machine design class that basically asks the same question. Any insight on when the angular velocity of both elliptical gears are at unity? Thanks.
12/14/2006 4:26 PM
http://www.stirlingsouth.com/richard/develop/engines_under_development.htm tells how they did it using a very easy to follow explanation.
Wm. Scott Smith
Register to Reply 8 comments
Anonymous Poster (1); bhrescobar (1); lgeo (1); rakesh_semwal (2); scott712 (1); spaceman (1); Stirling Stan (1)
You might be interested in: Metric Gears, Bevel and Miter Gears, Gears
