Previous in Forum: Mechanical Shock   Next in Forum: Elliptical Gears
Wobbling Pump
11/29/2006 5:09 AM
I have to calculate the work done of a wobbling pump which works on the wobbling technique. In that what I have is the water pressure which drive the pump. So any one has any thing that can help will be appreciable.
Re: Wobbling Pump
11/30/2006 3:31 AM
It doesn't matter whether the pump wobbles or not. The work done by any pump is the product of the pressure rise and the volumetric flowrate. All one has to do is select compatible units to get the work done.
Re: Wobbling Pump
11/30/2006 8:52 AM
Different types of pumps are inherently more (or less) efficient than others. Don't forget to divide the power added to the fluid by the pump efficiency (less than one obviously) to get power required to run the pump.
Also, if you are using pressurized water to drive the pump (which is what I think you said) you will also need to account for the efficiency of the turbine (device that converts engergy from the pressurized water to mechanical energy to drive the pump.) I assume that these two devices are integrated so hopefully the manufacturer will provide overall efficiency of the turbine and pump combined.
Re: Wobbling Pump
11/30/2006 10:41 PM
Thank you 'dhanishd' I never knew what a wobble pump was untill today.
Now I do:-
http://www.animatedsoftware.com/pumpglos/wobble.htm
It says it can develop incredible pressures, so are you thinking of a water jet cutter?
"Neither man nor woman can be worth anything until they have discovered that they are fools. The sooner the discovery is made the better, as there is more time and power for taking advantage of it." William Lamb
Register to Reply 3 comments
Alastair Carnegie (1); Anonymous Poster (1); juba-jabba (1)
