We have a DVD player supported by an aluminum stand attached to a glass base with a diameter of 195mm and 8mm thick. There is a metal plate below the glass base to give extra weight. The metal plate is 185mm in diameter and 2mm thick. We need to meet a mechanical shock of 5G/3ms. With the above design, the system can passed only 3G/3ms. After several experiments, we find that if the glass base is replaced with a plastic base with the same diameter and 4mm thick (the metal plate is still below the plastic base), then the system can passed 5G/3ms. As I am not expert in mechanical shock and vibration, why is this so? I need an explanation to support our result. Can anyone help?
