Previous in Forum: what is the difference between bus sectionaliser and bus coupler   Next in Forum: Megger Reading in Low Voltage Switch Gear
ckt to lower output by a constant delta
06/03/2009 3:35 AM
hi, i have a certain voltage output(Vo) that I want to lower by a constant delta to produce Vi. Vi will always be about 200 volt less than Vo:
Vi = Vo - 200
Thanks,
Re: ckt to lower output by a constant delta
06/03/2009 3:42 AM
OK. So how do you want to do it?
06/03/2009 4:17 AM
I'm thinking of a zener diode ckt but just can't figure out how to do it
Good Answers: 18
06/03/2009 9:19 AM
Use an op-amp with voltage dividers to control drop across transistor.
Anonymous Poster (1); Bill (1); Dodskie (1)
