Previous in Forum: How to Size an Air-Operated Diaphragm Pump   Next in Forum: Water-Cooled Chillers
Good Answers: 11
Mach Number Through an RV
06/04/2009 1:28 PM
I was working on a project the other day with a process engineer when he told me that the program he was using to evaulate relief valve scenarios gave him a Mach number of 0.9 for one of our relief valves. We both thought this was incorrect since the vessel is at 70 psi pressure and ambient temperature. The orifice is an "M" sized orifice (I think this is about a 1" diameter opening).
It did make me wander what size orifice we would need to result in a Mach 1 speed through the orifice. I did similar problems in college so I thought I would treat it as a converging nozzle with a choked area. I quickly found out that I didn't remember as much about the topic as I thought I did so I thought I would defer to CR4.
Do I have enough information here to find the area needed to choke the flow? Assume we use air for the fluid.
Pathfinder Tags: Mach Number
Re: Mach Number Through an RV
06/04/2009 4:03 PM
Just factor what the area of the jet opening is and what volume you are sending through. High enough pressure though a small nozzle often works out to multi mach numbers!
Good Answers: 103
06/04/2009 9:34 PM
The orifice will have a 'Orifice constant' depending on the shape and that will provide the velocity on the form
Q=koAV
There is a link which explains this Ko for a few common shapes. For others the Fluid Mechanics text book may be consulted
http://www.mcnallyinstitute.com/13-html/13-12.htm
Good Answers: 183
06/05/2009 3:30 AM
The velocity is determined NOT by the orifice (M<=1) but by the pressures ratio.
For M>1 the nozzle (one cannot any more use the word "orifice") profile plays a very important role.
06/05/2009 8:54 AM
Agree with Nick name.Pressure drop is what determines velocity.
Roughly when P2/P1(outlet pressure/inlet pressure in PSIA) is 0.5 we have choked flow.
All normal relief valve sizing formulaes are based on choked flow.
That is why when the set pressure of relief valve is very low and there is a chance for back pressure to exist we need to be careful not to use the the ASME/API standard formulae
If you don't know where you are going,you are bound to get there
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
06/18/2009 11:26 PM
I use the following online calculator requires Java, it works great for determining flow properties through an orifice.
http://www.flowmeterdirectory.com/flowmeter_orifice_calc.html
Gannet (1); nick name (1); sb (1); srini (1); tcmtech (1)
You might be interested in: Pressure Relief Valves, Air Valves, Steam Traps
