Previous in Forum: Mach Number Through an RV   Next in Forum: Direct-Fired Absorption Chillers
Water-Cooled Chillers
06/04/2009 3:39 PM
What is meant by approach temperature in water cooled chillers? How can we find that? What is the approach temperature limit for the descaling of a condenser in water cooled chillers? can anyone help me on this?
Also, what is the ideal PH value of water used in chiller plants?
Re: Water-Cooled Chillers
06/04/2009 10:59 PM
This link should take you to a page that will answer your question about approach temperatures. The site also contains other useful information.
http://www.air-conditioning-and-refrigeration-guide.com/water-cooled-chiller.html
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
06/05/2009 6:47 AM
The approach temperature is the difference between the leaving water temperature and the refrigerant temperature. This is true for both the chilled water side, and condenser water side. It is determined by the manufacturing process. An inexpensive chiller with a small heat exchanger may have an approach temperature of 6C (10F). A more efficient chiller with a better heat exchanger may have an approach temperature of 1C (2F). The approach is sometimes mentioned in manufacturers literature--but not often. However, if the machine is working at full capacity you can take measurements, and calculate the approach. As dirt and scale build up on a heat exchanger the approach gets higher (worse). Descaling may bring the approach back to its original condition--but not better. Regarding the PH value of water in a chiller plant. Both closed circui and open circuit water systems should really have some additives to prevent rust of iron pipes, kill any organisms, and protect against freeze-ups in cold weather.
Register to Reply 2 comments
