Previous in Forum: Surface Treatments for Wind Turbine Mountings   Next in Forum: Building a Low Pressure Fog Machine
Abutment for Bearings
06/04/2009 11:37 PM
What is meant by abutment for bearings ?
Good Answers: 103
Re: Abutment For Bearings
06/05/2009 3:09 AM
As far as I know, it is the seating of bearing on a shaft or housing collar (that is called the abutment surface in bearing terminology), but what you mean- or from whatever literature you have seen it- may be context specific and that will not be proper to guess.
Good Answers: 120
Re: Abutment for Bearings
06/05/2009 11:50 PM
well, the abutment is the strong structure the bearing sits in that makes it stay in one place under the forces the armature creates under power, also called the bearing housing.
If you have a 1000 HP motor. that delivers enough power to move 550,000 pounds up at the rate of one foot per second. So if this is a mine hoist lifting 300 tons or so, the abutments must be capable taking this force without breaking.
In a bicycle, when you pedal, the lower bracket abutments that hold the bearings hold them in place as you pedal the bike
Per Ardua Ad Astra
Register to Reply 2 comments
