Previous in Forum: Abutment for Bearings   Next in Forum: Inlet and Outlet Valves for Centrifugal Pumps
Building a Low Pressure Fog Machine
06/04/2009 11:50 PM
Good day everyone,
I want to build the low pressure fog machine, the existing machine on market either too much pressure ie a lot of smoke or too expensive.
Can anyone give me an idea how to build one?
Thanks in advance
Re: Building the low pressure fog machine
06/05/2009 12:44 AM
Buy an existing machine,(one that makes too much smoke), take it apart and make it better.
Good Answers: 101
06/05/2009 1:06 AM
The easiest way to meke one is to add dry ice to water. Use a valve to regulate the output.
06/05/2009 3:16 AM
Johnson's Baby Oil (usual disclaimer) is used in model-making circles as basic smoke. It is simply dripped onto a warm electric element, usually energised from a 12VDC supply. Hornby model trains (usual disclaimer) used the system extensively in their proprietary models, so the cheapest way to do it is to dismantle a broken locomotive found on the secondhand market and recover the smoke unit. About £10GBP might be enough to obtain one.
DVader1000 (1); lyn (1); PWSlack (1)
