Previous in Forum: Perceptions on SUSTAINABLE DEVELOPMENT   Next in Forum: Sustainability through Vegetation and Organic Resources Conversion – I
Steam Turbines and NEMA Standards
06/08/2009 6:26 AM
The allowable forces on rotary equipment due to piping as per NEMA(National Electrical Manufacturer's Association) is a function of diameter only. What is the logic? The steam turbine weights vary very much from lowest MW capacity to higher MW capacities. It will enable higher resistance for pipe forces. Is it not?
Re: turbine allowable forces
06/08/2009 6:34 AM
Something to do with pressure and the shell thickness, maybe?
Re: Turbine Allowable Forces
06/08/2009 8:17 AM
Agree but there are several other factors to be considered like Diameter Support Design Type of Inward/ Outward Bearings Suction forced/ natural (for turbines only)
You can't save a file naming "Con" - Expert
Register to Reply 2 comments
