Previous in Forum: Pressure Vessel - Flange Thickness Calculation   Next in Forum: Calculation for Mitre Bend
Fracture Toughness
06/08/2009 8:08 AM
I am using this equation to calculate fracture toughness with unit MPa*m^0.5: KIC=0.016*(E/H)^0.5 * (P/c^3/2).
I data for this formula: E - 92 GPa, H - 5.708 GPa, P - 200 gram, c - 27.5 mkm.
What will be KIC? Thank you for your help.
Good Answers: 183
Re: Fracture Toughness
06/08/2009 2:33 PM
Could you please give what is around the formula you use since I have the feeling some thing is wrong.
I shall explain after seeing the input around.
06/10/2009 10:57 AM
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TXM-4NC5VBW-2&_user=709078&_coverDate=05%2F15%2F2007&_alid=931029425&_rdoc=1&_fmt=high&_orig=search&_cdi=5594&_sort=d&_docanchor=&view=c&_ct=1&_acct=C000039640&_version=1&_urlVersion=0&_userid=709078&md5=28b16fddf1db925a2412e3037d1566fb
Good Answers: 183
06/10/2009 5:34 PM
tried the link and got following answer you made some where an error
Sorry, your request could not be processed because the format of the URL was incorrect. Contact the Help Desk if the problem persists. [SD-001]
I shall have a look as soon as I get the right connexion
06/08/2009 4:38 PM
I've jus gotten this equation from the published paper. There are several ways of calculation of fracture toughness. The authors gave directly this formula without above-mentioned equations. The simplest one is I have given here. Many people use this equation to calculate FT. I think the main problem is to get final unit MPa*m^0.5.
Good Answers: 183
06/09/2009 3:05 AM
Can you make a scan of the page and put it on the thread or indicate the source since I do not see the reason for the P=200 grams! May be I am wrong but...
