Harley Davidson point ignition system uses a dual lobed opener, 1 wide lobe for rear cyl firing, 1 narrow lobe for front cyl firing, even tho both cylinders fire at the same time, one on compression stroke while other cyl is on waste or exhaust stroke. What are ways to see that each point gap is equal (.18/.20) as it comes around to fire and how do you adjust so that each is equal?
and, Tools used?
This is an old timer HD Q&A and will quickly eliminate the know it all harley guy that thinks he was born with a wrench in his pocket and a HD tattoo on his butt. You know the guy, 70 wt A/C oil (why) and single hole crank pin (why) talks with his heart not his brain. Just 4 fun
