Previous in Forum: Hydraulic Cylinder Repair Kits   Next in Forum: Motor Help
Reducing Fan Coil Motor
11/30/2006 9:49 AM
I installed FCU with a 1hp single phase motor, it produces humming sound, can i replaced it with 1/2hp motor to eliminate humming sound. its installed above ceiling because there is no other way to installed it.
Re: Reducing Fan Coil Motor
12/06/2006 12:13 PM
Any motor change would effect the performance of the fan coil unit. The manufactures data would help you with that. The noise may not be from the motor. A more likely enemy is air flow or blower blade vibration.
There may be no stupid questions - Some are just poorly contrived !
12/06/2006 11:58 PM
thanks..
but it seems like a humming sound, vibrating from motor to cabinet. does 1hp and single phase makes this, i heard 1hp motor is like this if its single phase. But thanks anyway.
Good Answers: 19
12/28/2006 12:31 PM
Balance the motor shaft with the coupling in a lathe.The balance is out.
06/17/2008 3:24 AM
The manufacture of fan coil should gurantee that there is no significant sound, otherwise a vibration pad should be installed.
Sami
Register to Reply 4 comments
ducon (1); philroth (1); Sami (1); ustrux (1)
You might be interested in: Ceiling Fans, Ceiling Tiles and Panels, Sound Cards
