Previous in Forum: Aviation Fuel Piping?   Next in Forum: Compressed Air Calculation
Oil Seals vs. O-Rings
06/10/2009 12:38 AM
What is the difference between oil seal & O Ring... and its application....
Re: oil seal Vs O Ring
06/10/2009 1:46 AM
What is the material of oil seals and O ring?
06/10/2009 1:49 AM
function of oil seal and O ring are same they made for sealing
but they are different in construction and application. some oil seal are made of special neoprene rubber material and having spring instead while O ring are also made of special rubber material. Oil seal used generally with rotating and sliding component while ORing is used with stationary part.
06/10/2009 1:52 AM
So it is decided to the material and exact work enviorment!
What is the material of oil seal and O ring do you need?
Good Answers: 53
06/10/2009 3:07 AM
An ORing is round in shape but oil seal shape can dependent on application, every ORing can can be called an oil seal(provided it is made of rubber) but every oil seal can not be called and an ORing.
Good Answers: 103
06/10/2009 3:29 AM
If you mean lip seal by the oil seal
Then O rings are usually best for static sealing and a small range of dynamic sealing (low RPM/ surface speed,, reciprocating motion) etc.
The lip seals are usually used for much higher velocity. Almost always for Rotary motion, but there are a few special seals for the linear one too, but are limited by the pressure handling capacity.
Good Answers: 16
06/10/2009 8:27 AM
We all know what an O ring is. An oil seal is accomplished when oil is flung off a series of rings by centripetal force connected to a rotary to provide a thin film of oil. Pressure differentials between the rings isolate different gasses (ie; hydrogen-air) without mechanical contact, as in an O ring. Other mechanical seals are called 'gaskets'.
De gustibus non est dispudandum.
Re: Oil Seals vs. O-Rings
12/18/2015 12:30 AM
One difference would be its construction...
This is an O ring.. Almost always Circular in shape and a tube in width. Used in general sealing applications.
This would be an Oil seal... Grooved according to the application and almost always used in rotary applications... like Shafts..
Register to Reply 7 comments
Anonymous Poster (2); MichaelZhu (1); PVL (1); rakesh_semwal (1); sb (1); Tippycanoe (1)
You might be interested in: Oil Seals and Grease Seals, Metal Ring Seals
