Previous in Forum: Compressive Load From Torque   Next in Forum: Oil Seals vs. O-Rings
Indonesia - Member - New Member
Aviation Fuel Piping?
06/10/2009 12:12 AM
Dear Friends
I have question about avtur (aviation fuel) piping
Avtur properties are : Density 775-840 kg/m3
Flash Point : 33 oC
Total Sulfur : 0.3 % m/m
Considering above data.
How much the corrosion Allowance?
How about internal coating/lining, what material should i use?
Would you show me the coating/lining method?
Thanks
Best Regards
Fendy
Re: Aviation Fuel Piping?
06/10/2009 12:37 AM
Due to the potential liabilities involved, you should contact the supplier of the piping, not solicit anonymous advice.
06/10/2009 3:20 AM
Cotact the aviation fuel supplier for best practice advice. Selecting the piping material correctly will mean that no corrosion allowance is necessary. Corrosion in a fuel pipe, and eventual failure, may mean the destruction of the entire facility!
Register to Reply 2 comments
