Refurbishing Axis guides
We have 100 mm x 200 mm x,y axis table. Axis is mounted with magnetic linear motor and glass scale. Accuracy of the axis are 0.5 micron for the entire travel range.
Axis guide are not separately mounted on the body of each axis. We are using the axis to cut diamond. Now, after several years of usage the guide having pitting on it and it obstracts the smooth movement of axis.
Is there any solution to remove pitting? If we grind it, the accuracy level will be disturbed .Also we will not be able to have matching rollers.
Then how to fill the pitting which is hardly 1 mm deep?
Please guide me.
