I'm still a student in mechanical. Recently i visited a hospital that use a hot water boiler and a calorifier in its hot water supply system. The system is used only to supply hot water to the hospital, no space heating or other else.
The water in the primary circuit and secondary circuit is just the same or directly from the local water supply, i.e. the water in the primary circuit is not treated. The water leave from the boiler is not in the steam phase. The temperature in the boiler is set to 90°C and at the calorifier is 60°C.
Why they didnt use direct heating instead of indirect heating by using calorifier like the above. I think the system is wasting the fuel, cost and energy. Any comment or any other reasons for using calorifier?
