Previous in Forum: Generator Frequency   Next in Forum: Types of Fuses in an Electrical System
Protective Relays for Synchronous Generators Running in Parallel
06/10/2009 11:14 PM
Hi Guys.
Would like to know in detail the different protective relay system for synchronous generators operating in parallel.
I know that there is the Cross Current Compensation system, the differential current fault relay system and the overcurrent/earth fault protection system.
I am aware that there are other protection system too.
Greatly appreciate if anyone of you could furnish me with a detailed explanation of the other protection systems
Thanks a thousand !
Newbie Enginner
There is no limit towards how much one can learn.
Re: Protective Relays for Synchronous Generators Running in Parallel
06/11/2009 6:46 PM
how about starting by looking at the specs of the engineered build. also checking to see if there are any inputs to your PLC in the switchgear
You might be interested in: Protective Packaging, Laser Protective Eyewear
