Previous in Forum: Protective Relays for Synchronous Generators Running in Parallel   Next in Forum: Counterpoise and Fuse Detectors
Types of Fuses in an Electrical System
06/11/2009 3:24 AM
Plz tell me what are the different types of fuses that are used in electrical system
Re: What are the different types of Fuses that come under electrical
06/11/2009 3:54 AM
06/11/2009 5:10 AM
There is only 1 type, it is call an Electrical Fuse. A litter small wire connected across between both end of the contact cap.
In electrical system, we don't use these fuse anymore, we use MCB or MCCB. It much cheaper and easy to handle. "If it Trip, Just Reset It."
06/11/2009 5:44 AM
<...If it Trip...> FIND OUT WHY, ELIMINATE THE CAUSE, THEN <...Just Reset It.>
Good Answers: 103
06/11/2009 5:47 AM
Good Answers: 266
06/11/2009 7:51 AM
http://www.circuitprotection.ca/fuseology.html#FuseSelectionGuide
Fuses are typed by size and application see above for details.
Hobbies - Musician - Tube Amps Only Please!
Re: Types of Fuses in an Electrical System
10/30/2009 8:38 PM
Slo Blow Fast Blow Google fuses that should tell you.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Anonymous Poster (1); maveric_manic (1); ozzb (1); PWSlack (1); sb (1); Simon Wan (1)
You might be interested in: Fuses, Used and Refurbished Equipment
