Previous in Forum: Factory Supply Voltage   Next in Forum: Neutral to Ground in Three-Phase Generator
Ratings and Cable Sizes
06/11/2009 7:48 AM
what ratings and cable sizes would you expect these circuits to be:
a lighting circuit
a ring main
a supply to an immersion heater
a supply to a shower
a fused spur
a supply to a cooker
Re: ratings and cable sizes
06/11/2009 7:49 AM
British Standard 7671 again.
Good Answers: 266
06/11/2009 8:14 AM
On all of these items the ratings could change due to local codes and circuit load is the determining factor for conductor size which is not given. Example is a dish washer in your home has an immersion heater. May be 20 to 30 amps maybe 120 or 240 on a stand alone unit any of these would change the cable size or type the plug also. Then there is immersion heaters for industrial use. Your items are not defined enough to give a definitive answer.
The supply to a shower is water so no cable is needed just pipe.
Good Answers: 38
06/11/2009 10:50 AM
Sounds like homework!
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Re: Ratings and Cable Sizes
06/11/2009 3:57 PM
This really looks like homework, and is impossible to even answer as the cable size varies with load and supply voltage (which varies from country to country). "a fused spur" and "a ring main" are even more vague.
What the heck crazy shower requires power.
<sigh> before this thread is closed, what course are you doing and why didn't you pay attention in class (either in person or online).
06/11/2009 8:23 PM
It really a homework. It doesn't even tell us how much is the total connected load to each circuit.
06/11/2009 11:53 PM
That's generally explained in the coursework leading up to the question, as is the answers (or at the very least enough information to obtain the answers without outside help).
charsley99 (1); jack of all trades (2); ozzb (1); PWSlack (1); Simon Wan (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Spur Gears
