Previous in Forum: Elevators and Energy   Next in Forum: Variable Voltage VFDs and RPM Control
Transformer Impedance and kVAr Compensation
06/11/2009 12:20 PM
For calculating Transformer Impedence compenseting KVAR of 2000KVA Transformer
Transformer rating is 2000 KVA
Impedence of the transformer is : 6.25% (As per the vendor)
Let X be the total load in KW
So total load in KVA = KW/ P.F
Intial P.F is 0.8
Improved P.F should be = 0.99
Can any one let me know what is the base formula for calculating Transformer Impedence compenseting in KVAR
compenseting in KVAR = =Square of loading of trans X %Z X Rating of Trans
Could any one the basic of the formula where it is derived from.
%Z
Re: Transformer Impedance and kVAr Compensation
06/11/2009 8:23 PM
You need to add load to the transformer first. Your caps are installed to correct the load and not the transformer to the power factor you want.
06/15/2009 1:57 PM
Be careful correcting the transformer power factor to above 95%. You always want to remain in a lagging power factor. If you go past 100% you are in a leading power factor. The load determines power factor and loads can change as they switch on and off. good luck
Register to Reply 2 comments
