Previous in Forum: hvac piping   Next in Forum: HP Air Bottle Sizing Problem
8 comments
Thermal insulation
06/14/2009 8:21 AM
Hi all,
currently we are using calcium silicate for insulating steam pipes.Please suggest me the efficient insulating material than calcium silicate so as to reduce insulation thickness
Steam temp: 350 deg
Good Answers: 61
Re: Thermal insulation
06/14/2009 11:27 AM
Check out this selection table.
http://www.engineeringtoolbox.com/insulation-temperatures-d_922.html
Do it once and do it right
06/15/2009 10:21 AM
You might want to look at polyurethane.....has an R Value of 7-8 and melts at 280C.....should work, is flexible, and twice or more the R value of calcium silicate, so can be thinner.
06/15/2009 12:11 AM
What is the service? Pipe or vessel? Is maintenance frequent causing damage to calcium silicate?
06/19/2009 11:25 AM
It is on pipe of 150NB
No frequent service is required
Material is used in marine application
06/21/2009 2:40 AM
For marine application, lightness is important. Use mineral wool
06/15/2009 8:05 AM
Dear,
C.S is good for steam pipes conveying steam and is the best material with thin wall thickness application.
The best is MINERAL WOOL. But the thickness of this application (approximately )will be three to four times that of CS.
But can withsatand up to 1000 digrees.
Karan
Send me all new Engg ideas & news......I will be your best friend-------KARAN
10/12/2009 4:21 AM
Microprous insulation , this is more efficiently than CS and Thicknes also 3 times lesser than CS at the same temprature requirements.
yuva...
11/27/2009 11:12 AM
There is a relatively new product available now called Pyrogel XT that is manufactured in rolled sheets approximately 1/4" thick that can be applied in appropriate layers to fit your specifications. It's upper temperature limit is 1200 degrees, so it would easily meet your requirements. Of course, this product can be protectively jacketed to meet your needs as well. One particular advantage is that it is re-usable to a greater degree than calcium silicate, which often breaks or crumbles when disturbed for maintenance work or inadvertant contact with the insulation system.
Rick
Register to Reply 8 comments
Anonymous Poster (3); b v rao (2); karantb (1); PennPiper (1); speeddemon (1)
