Previous in Forum: jet engine air flow   Next in Forum: Thermal insulation
hvac piping
06/14/2009 3:16 AM
hi ,
i need information of chilled water ( 2 deg centigrade)and hot water (50deg centigrade) pipe fabrication and installation procedures of 150 mm dia M S pipes with 5.4 mm thick walls
panyamnr
Good Answers: 68
Re: hvac piping
06/15/2009 2:46 AM
Hello panyamnr,
Welcome to the site. We are a friendly lot here and there is some very knowledgeable people here, I hope you stay with us and help other if possible.
To start can you look at this site. It seems to deal with the technical side of connecting cold and hot pipe, from the small bit of the site I read.
http://www.wbdg.org/ccb/VA/VAASC/VA%2023%2007%2011.pdf
Keep in touch please,
bb
Re: hvac piping
06/15/2009 4:33 AM
Refer to the end Client's piping standards.
Re: hvac piping
06/15/2009 9:23 AM
If you wish to use PEX on potable water... www.seatech.com
on the chilled system...use PEX or PVC and wrap it..or go to
www.urecon.com if you have money...good stuff
Register to Reply 3 comments
Anonymous Poster (1); babybear (1); PWSlack (1)
You might be interested in: HVAC Services, HVAC Controllers, HVAC Ductwork
