Previous in Forum: Voltage Flactuations for AC 3Phase Motor   Next in Forum: Earthing
IC design
06/15/2009 2:39 PM
How can i design of IC febrication?
Good Answers: 62
Re: IC design
06/15/2009 2:41 PM
Use of the IC, or fabrication of the IC itself?
Re: IC design
06/15/2009 3:52 PM
Creation of an integrated circuit foundry as a backyard project is not possible. The answer is you cannot.
Can you please elaborate?
Good Answers: 62
Re: IC design
06/15/2009 4:02 PM
would be fun tho....
Re: IC design
06/15/2009 11:08 PM
An April Fools day DIY guide perhaps....
Step (1) - Using your morter and pestle, grind white beach sand into a fine powder and mircowave on high for 20 minutes. Congratulations you now have your silicon base, now get out your gold pen (very fine tip) and microscope as its time to lay down those tracks.
Re: IC design
06/15/2009 9:13 PM
Start with VHDL (Very High Speed Intregrated Circuit Hardware Description Language for FPGA) or Verilog (Verification Logic for ASIC), then send to Synthesis software. Then to Place and Layout. Then to the foundry.
An analog chip is a whole different problem.
And yeah, backyard fab is not possible.
Re: IC design
06/21/2009 5:56 PM
Hands-on: Get started in analog IC design and fab (a three part article)
http://www.planetanalog.com/showArticle.jhtml?articleID=217701382&cid=NL_planet
This covers your question nicely.
Register to Reply 6 comments
Anonymous Poster (1); edignan (2); jack of all trades (3)
