Previous in Forum: Sizing Motor Feeders   Next in Forum: Maintenance for MCCBs
India - Member - New Member
Earthed Cables and Unearthed Cables
06/16/2009 2:58 PM
What is the difference between earthed cable and unearthed cable? How we can measure the both cable voltages?
Arun Babu
Re: Earthed Cables and Unearthed Cables
06/16/2009 5:00 PM
An earthed cable has an earth wire, an unearthed cable has no earth wire.
http://en.wikipedia.org/wiki/Ground_(electricity)
Do you mean earth screened or shielded cable?
http://en.wikipedia.org/wiki/Shielded_cable
06/17/2009 4:35 AM
Is an "unearthed" cable and "unarmoured" cable the same??. In india we call an unarmoured cable as flexible cable also
Regards,
PG
06/18/2009 8:10 PM
They may be called the same but they are quite different. An armoured cable is a cable which has an armoured covering around the cable which may or may not be earthed (depending on circumstances). An unearthed cable generally means a cable without an earth wire.
Try goggling "cable glossary" for more information.
Register to Reply 3 comments
