Previous in Forum: Weld Factors and Fillet Welds   Next in Forum: Internal Coatings for Flow Lines
Thread Strength Calculation
06/17/2009 2:56 AM
I have two bolts under compression load and want to determine which one is the strongest. Both are manufactured from stainless steel 304 material. The one is an M40x2 pitch (OD40 & ID 37.4mm) and the other is a 1 ½" BSW (OD38.1 & ID32.7mm).
According to my calc the 1 ½" BSW have the lowest engagement length 114m vs. 144mm. I want to check my calculations please.
Good Answers: 183
Re: Thread strength calculation
06/17/2009 3:15 AM
Present them and you will get comments. There are at least 3 persons very able to answer you question but surely you will get much more comments. It will be up to you to discern the good and the less good.
Good Answers: 51
06/17/2009 3:36 AM
This should help you:
Bickford - "An Introduction to the Design and Behavior of Bolted Joints"
Sorry to not elaborate on it - I am going to bed.
A little knowledge is a dangerous thing.
Good Answers: 103
06/17/2009 7:41 AM
I am getting only about 15% difference (of course I am calculating for tension rather than compression) and for that it is 114 (if I take for the BSW) then M40x 2 is 129mm
the 114 value I am taking at random (since the female tapped hole material and strength is not known)
for j=1 it is only 32.95mm vs 37.56 mm
But again materials being same, the same proportion should apply .
May we have a look at the calculations?
Good Answers: 137
Re: Thread Strength Calculation
06/18/2009 11:23 AM
Are you sure that's a metric bolt, not some other thread? e.g. electrical. Nearest metric bolt is M39 with 4mm pitch, but this is a non-preferred size. Nearest preferred size is M42 with 4.5mm pitch. That's for metric coarse threads, the ones you get if you don't specify fine. Fine thread pitch is typically 0.6 - 0.7 x coarse.
1½" BSW has 6 TPI, so pitch is 4.23mm.
Cheers.........Codey
Good Answers: 103
06/18/2009 12:20 PM
M40x2 do exist along with pitches 1.5,2.5 and 3
Of course highly non preferred but still they are there like I never heard about M17, M18, M22 till came face to face with M22 then the search yielded these along with a lot others like M25, M26, M28,M32...
Codemaster (1); nick name (1); sb (2); XMech (1)
