Previous in Forum: Reducing Tee   Next in Forum: Helicopter Auxiliary Gearbox
11 comments
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
AF Size for M160 Bolt
06/17/2009 5:47 AM
Was wondering if anyone can point me in the right direction here.
Looking for the AF size for a metric heavy hex nut to suit an M160 bolt.
I have the standard BS 4190:2001 but that only goes as high as M150.
Thanks in advance for any help.
Kev B
Pathfinder Tags: AF bolt hex nut
Re: AF size for an M160 bolt
06/17/2009 5:54 AM
Wow! that's some bolt, Kev!
Good moaning!
06/17/2009 5:57 AM
It certainly is.
Thankfully, it is the largest one I am working on!!
06/17/2009 6:54 AM
Please check it
www.superbolt.com
No so big wrench need
devitg
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
06/17/2009 10:02 AM
With a bolt that size, Kev would be spending days chasing his tail as he winds down myriad jacking screws
Hydraulic Nuts, another alternative, would be an ideal option for something like this. Here's a link if anybody is interested.
Best regards, HeviiGuy
06/17/2009 2:50 PM
With a simple air power impact wrench , he will do it easy , and a lot less space .
No room space for the classic wrench lever.
Good Answers: 183
06/18/2009 6:06 AM
As answer to your comment I want to stress that for such huge threads torquing is not a recommended procedure. It is much more convenient and presents much more advantage to use stretching since the tensioning allows a higher pre-load (due to lack of torque shear) and the sensitivity to friction dispersion disappears.
To give you an order of magnitude depending on the equivalent friction coefficient considered same for thread and nut/head contact area the torques and forces at the elasticity limit are:
class 8.8 µ= 0.1 T= 380 kNm F= 18.4 MN µ=0.2 T= 653 kNm F= 15.4 MN (1MN=1.000kN=1.000.000 N)
class 10.9 same µ-s T=324 F= 15.7 T=557 F=12.6 same units as above
class 8.8 same µ-s T=225 F= 11 T=387 F=8.8 same units as above
Using stretching (tensioning) the pre-loads are for 12.9 F=20.2/10.9 F=17.2 /8.8 12 MN.
It is easy to recognize the advantage. Values computed at elasticity limit. Can be adjusted according to accepted limit. Those values are INDEPENDENT of the friction and have the dispersion of the equipment which is limited to the seal friction or even less if tensioning is combined with an elongation measurement.
Good Answers: 183
06/17/2009 1:13 PM
AF = 248 (rounded 250) H = 137 (rounded 140) in mm
Extrapolated as AF=1.6*d and H= (0.8...1)*d
There is a geometrical similitude for all dimensions proportional to nominal diameter "d"
Examples:
M 10 20 30 42 48
S=AF 16 30 46 65 75
S/d= 1.6 1.5 1.53 1.55 1.56 mean =1.548
H 8.4 18 25.6 34 42
H/d 0.84 0.9 0.85 0.81 0.875 mean = 0.855
Hope it will help.
06/18/2009 4:00 AM
Thank you very much Nick Name.
That info will come in very handy.
Cheers to all other posters too.
Kind Regards
Kev Brown
Re: AF Size for M160 Bolt
06/18/2009 9:47 AM
I have heard a rumour that the dimension I am looking for is in standard ASME B18.2.4.1
Does anyone have access to this standard so they can check for me please?
Kind Regards
Kev Brown
Good Answers: 51
06/18/2009 3:51 PM
I have access to it (and others),
and ASME B18.2.4.1M only covers up to M36X4
& B18.2.4.6M only covers up to M100X6
I have never dealt with sizes in the M160 range, so I will have a look to see if there are any references to other standards.
A little knowledge is a dangerous thing.
Good Answers: 103
06/18/2009 11:59 PM
DIN 931-2 covers upto M160x6 bolts But I have to check up whether our library has the copy (doubtful)
Register to Reply 11 comments
Anonymous Poster (1); BoltIntegrity (1); Crabtree (1); devitg (1); Kev_brown (3); nick name (2); sb (1); XMech (1)
