Previous in Forum: Bus Bar Current   Next in Forum: Sizing an Incoming Breaker
Cable Size Selection
06/17/2009 8:45 AM
please give me a guideline for selection of power cable size. if possible please give me the standard that shows the relation between current rating and cross sectional area of a copper wire with in a definate length?
Good Answers: 18
Re: cable size selection
06/17/2009 3:14 PM
The greater the Amp draw, the bigger the cable.
In the U.S. refer to NEC Article 310 - Conductors for General Wiring.
Below is a link to an online calculator that might help:
http://www.electrician2.com/calculators/wireocpd_ver_1.html
The most valuable of all talents is that of never using two words when one will do. ~Thomas Jefferson
Re: Cable Size Selection
06/18/2009 9:06 AM
The sizing of cables is relevant to ambient temperature & many other things. Consequently, your location, how you wish to install the cables, the type of load, the length of the cables, the location of the cables etc will dictate the size of the cable.
Generally speaking, you must use local rules, regulations & standards to ascertain the size of a particular cable.
"If you try to keep a leg each side of a barbed-wire fence, you'll do yourself a mischief." - Joh Bjelke-Petersen.
Anonymous Poster (1); EElectrician (1); elkangorito (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
