Previous in Forum: Electric Motor Design   Next in Forum: cable
Stepdown Voltage
06/18/2009 10:49 AM
how to step down 220v ac to 5v dc supply with out a transformer?
Re: step down ac supply
06/18/2009 10:57 AM
Rectify, then voltage-regulate. It will be less efficient than a transformer, so those components are going to need to survive cooking.
Good Answers: 73
06/18/2009 11:11 AM
The MAX5022 evaluation kit (EV kit) is a fully assembled and tested 5W flyback converter circuit board. The power supply is configured for an isolated +5VDC output voltage that can supply up to 1A of current. The line input voltage range is from 85VAC to 265VAC or 120VDC to 375VDC.
Check out this link http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3011/t/al
Re: Step down Voltage
06/18/2009 7:20 PM
It depends on how much current you require, but the short answer is you want either a switch mode power supply or a linear regulator with a full bridge diode rectifier. Try a google search of the above terms for much more information.
What's the application (how much current and how smooth an output do you require)? What are you trying to power?
Re: Stepdown Voltage
06/18/2009 8:32 PM
Just buy some power regulator that take input 220V and output 5 volts. There is a lot of these voltage regulator available in the market.
Good Answers: 103
06/18/2009 10:07 PM
When an Edgar asks a question which pre-empts the obvious and efficient (transformer+diode bridge here)
The answer is obvious - it is homework.
06/18/2009 10:14 PM
I do agree with you, Guru. It is a homework.
jack of all trades (1); NotUrOrdinaryJoe (1); PWSlack (1); sb (1); Simon Wan (2)
