Previous in Forum: Parallel Operation of Power Plant With Grid   Next in Forum: IEC 104 & 101.
Selection of Capacitor
06/20/2009 2:49 AM
How to select capacitor in PCC panel
Re: Selection of Capacitor
06/21/2009 4:08 AM
Hi,
dear I think you are asking about Power Factor Improvement capacitor selection.
rating of capacitors is in KVAr, and we can select capacitor according to our connected load, current power factor and required pawor factor.
fell free for any clarification
Regards,
rizwanad@gmail.com
06/21/2009 10:20 PM
How big is your PCC panel.?
What is the total load connected to your PCC panel.?
What are the load that connected to your PCC panel.?
What is the incoming Voltage of your PCC panel.?
What is the total current consumption of your PCC panel.?
06/23/2009 7:56 AM
Actually we have very old set up of power distribution & capacitor bank installed at different location of loads.
Incoming supply at 11KV receiving on VCB to X'mer & set down to 415V LT breakers.
Our maximum load is 4MW & connected load is 6MW.
Kindly clarify in details about selection of capacitor as per above load.
06/22/2009 3:14 AM
Contact the original equipment manufacturer and obtain a 1:1 replacement.
06/24/2009 10:54 AM
Seriously, stop trying to save 5 cents & go & ask a consultant. There are far too many unknowns in your question/situation in order to be able to safely & satisfactorily answer your question on the internet.
"If you try to keep a leg each side of a barbed-wire fence, you'll do yourself a mischief." - Joh Bjelke-Petersen.
anandtrivedi (1); elkangorito (1); PWSlack (1); rizwanad (1); Simon Wan (1)
