Previous in Forum: Isobaric Versus Isovolumetric-Combustion?   Next in Forum: Safe Drinking Water Development
Invisible Ink
12/05/2006 2:34 AM
I want to know that which ink is the best for to write on glass or any other surface it should be invisible to the normal light which can be read only by special light like infra light etc.with ink detail where it is availlable or web address & also i want a detail information on a mechine to engrave on the glass meterial.
Re: Invisible Ink
12/05/2006 11:05 PM
You can use ultra violetray fluorescence pen. so that you have to use uv lighting the words you wrote to display. if you are interested in the uv printing ink you can printing on material like grass and ceremic etc. we can offer you these ink and pen and other writting tool on grass etc.
Re: Invisible Ink
12/06/2006 1:40 AM
Hi.
Thankyou for replying to my request,if you have any dealer in india please send me the detail to nageshrao_sridhar@rediffmail.com
Re: Invisible Ink
01/29/2007 1:49 AM
dear sir, i am as an optician in pakistan i want write my company logo on eye glass that can only be seen by fog. please tell me how can i write invisible . thanx Asad
Re: Invisible Ink
01/30/2007 12:26 AM
Dear Guest,
My advice is that you use a masking techniques and blast a very small area, perhaps in the corner of the lens, with a very fine abrasive. You should after all want your customers to be proud of your Company Logo, discretely displayed just near the frame. Etching with HF acid in a fume cupboard might be an option? again masked, but I am not qualified to advise. Laser ablation is also a potential solution. perhaps demanding a slightly higher initial capital investment.
At a guess, a suitable adhesive tape could theoretically be used to protect most of the glass lens. The logo could be printed onto the lens in a water repellant ink and then a water soluble latex applied and allowed to dry. this layer of latex would become the mask. Well worth an experiment or two. A compressor from an old refrigerator would be quite adequate for such fine abrasive blasting. You might need to make a very fine abrasive blast gun. Two fine tubes meeting 'Y' fashion, i.e. one tube delivers compressed air, the other tube draws in fine abrasive from a reservoir, under 'suction' (pardon the expression)...Bernoulli Principle at work.
"Neither man nor woman can be worth anything until they have discovered that they are fools. The sooner the discovery is made the better, as there is more time and power for taking advantage of it." William Lamb
Re: Invisible Ink
12/06/2006 11:26 PM
Cnpower is right about the ultra violet pen, make sure it is a waterproof version, most 'security' marker pens are. As for engraving glass, why not go round and ask a local dentist if he has spare worn diamond drills he is throwing away. You can even use them without a drill. Just stick them in an old ball point pen with some epoxy glue/whatever. Or toy model maker supply shops sell suitable drills, a 12 volt one could work off a car battery. Good Luck.
Alastair Carnegie (2); Anonymous Poster (1); cnpower (1); nageshrao_sridhar (1)
