Previous in Forum: New CO2 Leak Detector by AccuTools   Next in Forum: ultrasonic flowmeter
How much do you know about Pressure Tank ?
06/30/2009 10:45 PM
Pressure Tank is an industry equipment ,which could widely used in chemical industry, chemical fertilizer production, paint ,wood ,PVC,plastic paint , machinery, mining ,shoe manufanture , light industry, electric power industry, and so on.
The pressure tank have different types .Such as :Without Mixer ,Manual Mixer ,Air Mixer .Without Mixer is a solvent tank ,which could make the mixed solvent come out from the tank by the air pressure .Manual Mixer could mixer solvent by manual ,but also could make the solvent come out from the tank by the air pressure .Air Mixer use air motor as power and mixer solvent.Using air motor as power will no danger ,long life, making material mix well ,and no deposit,save labor ,continuous operation ,low cost ,improve efficience ,increase profits ,100% explosion-proof ,therefore retaining the leading position in the marketplace.
It have different capacity .Such as :2L ,5L,10L,30L,40L,60L,80L.Specification can be customized accoriding different requirments .
It have different material inner .Such as quadrate tank ,circular tank ,iron tank ,stainless steel inner tank .The most advantage is easy to change the solvent and no need to clean the tank by using inner tank
The tank body have different types too .One tank body is made by one-off ,thickness is not uniform ,low performace with high air pressure ,which possible explosion.The other tank body made by jointing ,thickness is of uniform ,bear high air pressure ,100% explosion-proof.
Pressure tank have different brands in the market ,Such as "TONSON" big brand .If you want to know more brand ,you could search it by google or other engines. .
Re: How much do you know about Pressure Tank ?
06/30/2009 11:54 PM
What's your point?
07/01/2009 1:55 AM
I think he must be on commision to TONSON. He has mentioned them in 3 posts totally irrelevant to the subject being discussed.
Good Answers: 137
07/01/2009 4:08 AM
3 out of how many? He only joined in June 2009!
07/01/2009 4:58 AM
Sorry, got it all wrong, he mentions Toronson in 6 out of six posts, without exception out of context
Good Answers: 101
07/01/2009 6:09 AM
HULK SMASH LOUSY PRESSURE TANK TO BITS!!!!
Anonymous Poster (2); Codemaster (1); DVader1000 (1); Mikerho (1)
