Previous in Forum: Have you "Earthed" yourself today?   Next in Forum: Canbon Activated Alumina Sheet
Engineering Fields - Aerospace Engineering - Retired South Africa - Member - The Rainbow-nation Engineering Fields - Engineering Physics - Relativity & Cosmology Popular Science - Cosmology - The Big Picture!
Good Answers: 69
Think Lunar Elevator!
12/05/2006 2:12 PM
Space Elevator? That's old hat - the Lunar Elevator may be closer than you think!
The Russians have just entered the race to build a "space railway"—a system of cable-ways that can sling payloads to the Moon, writes Space.com in a very interesting article. It is aptly filed under a name that has a certain 'ring' to it: "/<date>_technovelgy.html". Now what on Earth does technovelgy mean?
Pathfinder Tags: Lunar elevator space elevator
Re: Think Lunar Elevator!
12/06/2006 7:28 AM
Why not just use a Boot-strap Jack?
Magnetic field? Think GRAVITY !
How about combining the MOHO project with the Space Elevator. Twice the Buck for the Bang!
Pass the 'Crack.'
12/06/2006 10:52 PM
Reading the article, I see this query:-
"...In reading about this, I found myself wondering where the energy for this will come from. Conservation of energy requires that the lowest tether, once it transfers energy to the payload, and boosting it higher, will fall to a lower orbit. How will it be raised again? One way is suggested by 'TUI', which is looking at using special tethers (cables) that can "push" against the Earth's magnetic field to move back up into position....."
Space Fountain Technology might be useful, i.e. 'active mass' internal decelerating mass holds the cable/fountain on the 'up' and acceleration on the way 'down', a closed loop. The advent of nano technology may be just what is needed. Power from acceleration and deceleration in a twinned cable could swap places with low losses. Wikipedia has a feature on all this stuff. Bravo to all those Russians, this sort of project is worth pursuing just for the educational benefits alone. How could one possibly get bored?
"Neither man nor woman can be worth anything until they have discovered that they are fools. The sooner the discovery is made the better, as there is more time and power for taking advantage of it." William Lamb
Register to Reply 2 comments
