Previous in Forum: Chemical Engineering Seminars   Next in Forum: Converting Volume into Area
Invention: The Irregular Heptagonal Polyhedron - Modular Recording Studios
07/02/2009 2:25 PM
Dear Sir, A European Patent Application of my invention the "Irregular Heptagonal Polyhedron" has been published some months ago in Munich Germany. My invention involves Architectural Acoustic design for modular recording studios for live music. This novel invention has attractive and innovating conditions to achieve true acoustic recording. Its structure is the result of some geometry operations starting from the heptagon. In would like to put into your consideration the EPO patent document of my invention (Abstract, Description, Drawings and Claims) to eventually consider the possibility to publish it in your magazine. Thanks, Abdullah Arellano
Friend of CR4
Re: Invention: The Irregular Heptagonal Polyhedron - Modular recording studios
07/02/2009 2:32 PM
Hello Abdullah,
You are welcome to publish it here, but note, we are an Internet forum for engineers and technical professionals - not a magazine/journal.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Good Answers: 101
07/02/2009 9:41 PM
You can publish the independent test report here under "Civil Engineering" to demonstrate its value. You can also publish your ad here under "Commercial Space".
