Previous in Forum: Invention: The Irregular Heptagonal Polyhedron - Modular Recording Studios   Next in Forum: Stiffness Method in Structural Analysis
11 comments
Converting Volume into Area
07/03/2009 11:47 AM
Hi , Im Maria...
I would like to know if somebody can help me with this.
Im working with some pollutant calculations, but i have my concentrations in volume units (ppm,ppb,ug/m3) and the software im working with aks me for area units...
I know i cant change volume units into area units...but i would like if there is any possibility of doing this??
i would need to convert ppm and ug(m3 into g/cm2..
THANKS....
Re: Units conversions
07/03/2009 12:08 PM
Here are some tables that may get you pointed in the right direction:
http://www.leatherchemists.org/conversion_table.asp
http://www.duncanrogers.com/tools/conversion.php
Don't know if they will help but good luck.
CARPE CRUSTULORUM!
Good Answers: 18
Re: Converting Volume into Area
07/03/2009 3:01 PM
Well, you can't convert volume to area except by dividing by one of the dimensions.
I think your software has a bug in it.
Good Answers: 54
07/03/2009 9:23 PM
I don't have much hope but this might help:
volume = area × height
So, if you can figure out what height you can work in, the area will present itself.
regards,
Vulcan
Good Answers: 101
07/03/2009 9:41 PM
Call the vendor: your software is defective. Unless you're talking about population density, concentration is ALWAYS measured in mass/volume.
07/03/2009 11:30 PM
Hi I am Amit...I hope this is helpful to you. I use this and keep it on my desktop as quick conversion tool....download free from this link http://joshmadison.com/article/convert-for-windows/
"Our Future is Limited Only by our imagination, & our imagination is only limited by our lack of tenacity. Imagination Plus tenacity equals invention." - Paul Gillespie
07/04/2009 10:08 AM
Since volume is length x width x height, make one of your factors 1 and then area and volume are the same. So if you're figures are in cubic feet, convert to 12 inches by 12 inches by 1 inch. Result is 144 square inches and cubic inches (1/12th of a cubic foot).
How can you be two places at once when you're actually nowhere at all?
07/04/2009 3:49 PM
Maria, it sounds like the same problem from my agricultural analysis background with USDA, where we determined the concentration of the species of interest in a water extract from a soil sample in ppm and reported it in either lb per acre or kg per hectare. The key was in the depth of the soil sampled. 1 acre-foot of soil weighs 4 million pounds. A 6-inch sample depth on the same area weighs 2 million pounds. So for soil samples, multiply the ppm by the appropriate bulk density factor, (2 or 4) to report lb per acre. Or make the simple conversions to report kg per hectare. This only works because most scientists in the field understand that the third dimension (depth) is set constant. In your paper you must report the actual depth sampled or your reviewers will let you know about it.
If you are doing pollutant analysis on a solid sample from which a weighed subsample has been subjected to an extraction process with a known volume of solvent, you need the bulk density of the material sampled. Then you need a protocol that isolates one dimension.
If you are testing surface water samples, you need additional data to relate the volume of runoff to the area from which it came.
07/04/2009 6:22 PM
Hi, well as your work at the USDA you should know or heard about the CityGreen (from the american forest www.americanforests.org). In order for the city green to run the analysys all the units should be in g/m2. But I created all my data bases with my data and it was in those units...
I will check what you wrote and tell you how it worked..
Thanks!!
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
07/05/2009 5:11 AM
hi Maria,
could it be possible that the software is asking for an entirely different thing? perhaps the area of the room, or space where these pollutants are found?
just a hunch.
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
07/05/2009 6:40 AM
For a rough calculation I think you can divide the room volume with the height.
Aged man is not old man...
Good Answers: 243
07/05/2009 11:22 PM
Hi, Maria.
Unlike the others, My guess is that the soft"ware is prompting you for the area of the sample capture media (filter) so so many grams per unit area of sample filter is the possibility I suspect.
By not describing how you took the samples, not knowing that you probably using a pump that collects and captures on a filter, what you describe makes no sense. But if the software expects the filter to be certain area, and based on a certain time of sampling, the software will likely then calculate the volume.
I also suspect it will take your final weight, and then figuring the standard pre test weight, calculate based on the difference automatically.
Thats my conjecture, having used pump type samplers before for industrial hygiene work.
hope this helps.
milo
Register to Reply 11 comments
Anonymous Poster (2); Bill (1); DVader1000 (1); Jerry New Hampshire (1); langyaw (1); Milo (1); Mitusha (1); not so smart (1); Qqberci (1); Vulcan (1)
