Previous in Forum: Measuring Trapezoidal Wires   Next in Forum: izod/charpy impact tester
8 comments
Measuring Compressed Air
07/03/2009 1:55 PM
i want to mesure 3000 cfm compressed airline from out side contact without connecting online kindly suggest
Re: Measuring Compressed Air
07/03/2009 8:06 PM
What do you want to measure?
  • Pressure
  • Flow rate
  • Temperature
  • Chemical composition
  • Refractive index
Please be more specific.
07/03/2009 11:53 PM
It would be interesting to know if there is a method/process to measure flowrate and pressure from outside.
07/04/2009 12:16 AM
flow rate
07/04/2009 7:12 AM
Try searching the 'net for "ultrasonic flowmeter"
07/06/2009 4:06 AM
Can ultrasonic flowmeters be used to measure gas flow?
07/06/2009 4:19 AM
http://en.wikipedia.org/wiki/Ultrasonic_flow_meter
The first sentence reads: "An ultrasonic flow meter measures the velocity of a liquid or gas through a pipe using ultrasonic transducers."
I realize one shouldn't take everything in Wikipedia as gospel, but I think (hope?) this one's correct .
07/05/2009 2:06 AM
u can use puematic to current transmiter.
07/06/2009 1:47 PM
It may be easier to monitor compressor power and pressure and estimate the flow with your compressors performance specifications or you can use generic ones.
I have not had very good luck getting accurate results with ultrasonic flowmeters.
Register to Reply 8 comments
Anonymous Poster (1); jagdip shah (1); JohnDG (3); PWSlack (1); Sadanand Jadaye (1); spencer (1)
