Previous in Forum: EMD special "file tools"   Next in Forum: Grundfos Pump 200x150x500 serial no 993532/2 Model;2RSKG4 Imeller size 510mm
Aluminum Wheels
07/04/2009 7:08 PM
¿ Does any one knows where can I get a visual inspection criteria and method for truck's aluminum wheels manufacturing process?
Thank you.
Ernesto
Re: Aluminum Wheels
07/05/2009 10:58 PM
I cannot tell you about visual inspection other than to look for cracks and pits, but usually the manufacturer will check them with a dial indicator to see if they are round!
Re: Aluminum Wheels
07/06/2009 1:43 AM
Non ferric parts can be checked for cracks or pin holes with dye penetrants. Some of the spray penetrant/powder developer types are messy and expensive when checking production volumes. One type, Zyglo, can be wiped, sprayed or dipped, rinsed off with water and checked with an ultraviolet light. By far the least messy. I don't know the cost.
Nothing exceeds like excess.
Good Answers: 12
Re: Aluminum Wheels
07/06/2009 12:08 PM
Here is a link to an Alcoa Wheel service manual with a section on inspecting wheels.
http://www.todaystrucking.com/images/AlcoaSVM_Manual.pdf
Register to Reply 3 comments
Anonymous Poster (1); Jaguar (1); Snave (1)
You might be interested in: Wheels, Filter Wheels, Aluminum and Aluminum Alloys
