Previous in Forum: electrical   Next in Forum: Need Utilities Software
17 comments
Just Need a Bit of Help...
07/05/2009 4:49 AM
I normally just google stuff and learn that way.... but of late iv hit a bit of a block. Im just having some good old fun building my own transformers and stuff and when i plugged it in the primary coil practically melted and was wondering why.
I also dont get why you can have an adapter and the primary coil can be made of like hair thin wire and have thousands of turns but mine had like.... fairly thick wire and 400 turns and it melted.... how does that work? I though that i could compensate for fewer turns by making the wire thicker.
Also i found that when i was first playing around with electro magnets a 1.5V AA produced a stronger magnet then a 9V (on the same coil) but the 1.5V would heat up the wire to a point where it was untouchable. Why does that happen?
Any info would be sweet, even if you just post a website i can learn from. thanx =D
6
Re: Just need a bit of help...
07/05/2009 5:01 AM
Ah, yes, you are asking the right questions.
The primary of the transformer relies on inductance...without sufficient inductance it is just like a short circuit and too much current will flow and the wire will melt.
to increase the inductance enough to make the current nice and low....guess what? You need a huge number of turns. Because the huge number of turns increases the inductance, the current drops to a sensible figure and you can use the hair thin wire.
The primary current would ideally be zero, but some current is used just magnetising the core back and forth every cycle....and of course, as soon as you draw current from the secondary the primary current also increases.
I hope this helps.
Reply Good Answer (Score 6)
Re: Just Need a Bit of Help...
07/05/2009 11:43 AM
CARPE CRUSTULORUM!
07/05/2009 11:51 AM
Quote "I also dont get why you can have an adapter and the primary coil can be made of like hair thin wire and have thousands of turns but mine had like.... fairly thick wire and 400 turns and it melted"
Yours melted because it did not have the resistance and reactance that the fine hair wire gives you with thousands of turns. You basicly had a short circuit.
07/05/2009 4:10 PM
First I'll discuss the transformer primary winding problem. The impedance of any real inductor contains the resistance of the wire added with the inductance. For a transformer it's the wire resistance plus the primary inductance plus the turns ratio coupled secondary load impedance. Zi=Rw+jωL+Zl Therefore Ii=V/Zi=V/(Rw+jωL+Zl) So by reducing both the primary resistance and the primary inductance by using heavier gauge wire you can significantly increase the current going through the primary circuitry. This does allow for more energy to be coupled through the core, an effect I believe you were hoping to obtain. However, when you include the thermal core losses (a nonlinear transfer caused by both eddy currents and hysteresis losses) to the heat load produced by the resistive losses of the wires, one will find that more useless heat will be generated with heavier gauge wire in a primary. If the core is redesigned to both remove this heat and reduce these core losses, you can couple more energy through the transformer. Another possible effect you could have is that you may have saturated the core with the lower gauge wire producing a higher magnetic flux. When the core saturates the peak current soars for both jωL+Zl drop nearly to zero above core saturation in the above equations. The core will not produce any more than the maximum heat when saturated but now the primary resistance heating will dramatically rise. (Yes, magnetics have non-linear effects.)
Now onto the battery confusion. A 1.5V AA battery can provide considerably more current than a 9V battery. Thus the output impedance of the AA is lower than the 9V. So when your coil was connected to the 9V the smaller current existed in the windings than with the AA battery. Thus less heat and magnetic fields were produced.
07/05/2009 7:25 PM
With respect, stop w**king. How do you think that could possibly help the OP?
Reply Score 1 for Off Topic
Engineering Fields - Electromechanical Engineering - Graduate Mechatronic engineer Engineering Fields - Control Engineering - Enthusiast
07/05/2009 11:14 PM
Please don't preface an insult by saying: "with respect"
some decorum, please.
RedFred's answer was probably just influenced by his enthusiasm for the subject, not out of a motivation to patronise others. I appreciate that his response was more technical than necessary, but at least I learnt something - which is why I'm here.
Regards,
TinTin
07/06/2009 12:18 AM
TinTin,
I thank you for my defense. But the shrillness of the attack actually appears to support my overly technical analysis. This is supposed to be an engineering forum after all. Technical analysis should be expected. But, I am a little disturbed that by working out some of the math in a format possibly just above the OP's background I could evoke an insult.
The OP's collection of information left several critical pieces of information out that I suspect he/she was unaware of. I intended to show in my analysis some of these missing pieces. I also intended to show that what appears to be a simple problem can quickly and surprisingly become more complicated.
Than You
RedFred
Good Answers: 196
07/06/2009 12:35 PM
redfred -- This has got to be a GA. I counted all the Greek letters and subscripts and that was good enough for me. (The semester that I took AC circuits I had a really hot girlfriend)
Last time I messed with a transformer I blew up a very nice Fluke 77 DVM. It's all "FM" to me.
Ed Weldon
Good Answers: 143
07/05/2009 7:56 PM
Study Faraday's Law to see
Good Answers: 103
07/05/2009 10:07 PM
The hair thin wire will have more resistance and hence will limit the current whereas the thick wire won't.
Assuming you are working on DC try to put a resistance in series to control the current to be a proper electromagnet. When my kid was doin it, I just advised him to but a normal torch bulb in series, but in case you want a better one, get some variable resistor. Else it will not only heat up the coil, but may spoil your power source too.
Remember for DC the L is virtually non existant and only the wire resistance (and the resistance of the source) is what is controlling your current.
07/06/2009 4:24 AM
The first thing is that by having several thousand turns of a light gague on the primary, creates a high resistance. Secondally a transformer requires an alternating current on the primary, this produces a back EMF (electro motive force) which in effect reduces the line current of the primary winding the internal resistance also limits the line current as well.
By reducing the No of turns and increasing the conductor size as you have done, it goes the other way, less turns less back EMF, less internal resistance, means higher current and more heat produced through Amps squared x resistance losses.
You are using AC supply arent you?
Also check the secondary winding of the transformer, that it is not shorted out.
One final thing that you should do, use fuses of the correct sizes on both primary and secondary.
Transformers are a science in themselves, of course you have a line transformer on a car DC ingnition but this is switching off and on several times a second creating an alternating dc supply.
In regard to the 1.5 v verses 9 v battery, i would think that the 1.5 volt battery had a higher MV.A Ratting than the 9 volt battery, in other words the 9 volt battery did not have enough energy to heat the winding.
If you are just trying to make a DC electromagnet, first find out what the current ratting of conductor you are using, then by using ohmns law calculate the required resistance you require so that you dont draw excess current, you probally want to de-rate the conductor dont run it a max unless it is for a very short time only.
By knowing the internal resistance that you require you can then calculate the meters of cable required to be wound, so you dont cook it.
May The Force Be With You
07/06/2009 11:49 AM
Batteries produce DC. Transformers use AC. The sine wave motion cuts the lines of flux to induce a current. Did I miss something?
Good Answers: 16
07/06/2009 7:02 PM
Designing and winding your own transformer can be fun and educational but you really need to take some precautions. As mentioned before, fuse it, don't pick too heavy of a fuse rating or it will just sit there and smile while your transformer melts. If you are just testing it for the first time, put a light load(s) on the secondary(ies) and use a light fuse, say one amp or two. Secondly, get a Variac and use that to control the primary voltage, worse thing you can do with a newly made transformer is to just plug it into the outlet unless you know what you are doing.
Do more research into designing and winding your own transformers. While the basics are relatively simple, executing a transformer design is not. You have to know the working parameters for the windings and current/voltage ratings, from there you figure out turns rations and wire sizes and how big a core you need. Wire size depends on the current loads and is determined by a given wire size cross section. Conservative current ratings is 0.5 to 0.75 times the rated current carrying capacity of a given wire size. The more conservative the current rating, the less heat loss and better voltage regulation but much depends on the magnetic properties of the core material as well. Many things must be taken into consideration to design a good transformer. There are books and information on the web to help. It is not possible to post all the details you need to do this job right on this forum.
Perhaps if you were to tell us a bit more about what your transformer is supposed to do we may be able to give you a little information and point you in an appropriate direction.
07/06/2009 7:50 PM
Well said.
Good Answers: 16
07/06/2009 8:24 PM
Thank you.
07/06/2009 11:39 PM
Hello Guest
Back to your project; Heavier gauge wire up stands more current but you need high enough inductance to keep your resulting prime impedance high enough; this is why your purchased transformer has thin wire and more turns in the prime coil while the secondary has heavier gauge wire to up stand higher current.
Safety precautions: wear glasses, have a 1 amp fuse in series with your starting project, try not to be alone in case you need help, use a wood table or work bench and be careful
Let's start with basic concepts:
1 Resistance is the opposition offered by any matter against the flow of Direct Current, the unit of measure is the ohm, Kohms (1000 ohm or Megohms 100000 ohm), and this opposition is responsible to transform the electric energy in to heat.
Some metals offer low resistance (less than 1 ohm per inch) to current therefore are considered conductors where silver has the first place among the elements, cooper and gold are good too but cooper is more often used because it is abundant and relatively inexpensive.
Plastics, dry paper, rubber, ceramics offer high resistance, it is so high that most meters are not able to measure it therefore it is considered infinite.
In between are the resistors like carbon, graphite, iron, actually those are the most common materials.
R=E/I Where R for resistance, E for voltage and I for current
2 Direct Current or DC is the quantity of electrons flowing in one way in a given moment, the unit of measure is the Ampere but DO NOT measure current unless you open the circuit to connect your Amp meter in series.
I= E/R
3 Alternating Current. Same as DC only that changes polarity at a given frequency, in the USA the frequency at your domestic AC power plug is 60 cycles per second.
4 Voltage is the pressure field applied to the electrons to move, the unit of measure is the volt.
E=I.R
5 Power is the amount of energy transformed in a given time. The unit of measure is the Watt for electrical power.
This means that you can do the same job using high voltage times low current like in the motor of your air conditioner or do the job with low voltage times high current like in the start motor of your car.
W= I.E Where W for power
120V*5 Ampere = 600 Watt at your air conditioner motor
12V * 50 Ampere = 600 Watt at your car's start motor.
The grater the current the heavier the wire gauge is needed to allow a great quantity of electrons flowing.
6 Inductive Reaction or chock. It is the opposition of the coils to a given frequency and is caused by a 90 degree delay offset against current respect to the voltage; this opposition to the flow of current does not generate heat.
7 Capacitive Reaction. It is an opposition caused by a 90 degree delay caused by electric capacities or capacitors to the voltage in a given circuit; this also does not generate heat. This is opposed 180 degrees to the Inductive reaction (In fact the frequency tuning occurs when the Inductive reaction and the capacitive reaction are vector ally equal but in opposite directions, they both null the opposition), the unit of measure is the ohm.
8 Impedance. It is the resulting vector of opposition from a combined circuit of resistance, Inductance, and capacitance, the unit of measure is the ohm.
9 Inductance Is the capability of a circuit (typically a coil) to transform electrical energy in to an electromagnetic field, the unit of measure is the Henry.
10 Primary to Secondary turn's ratio. Voltage is directly proportional to the turns ratio while current is invert ally proportional.
11 Core or K. It is the inductive properties of a ferromagnetic core to increase the inductance of a circuit at a given frequency; laminated iron is normally used for low frequencies like audio or industrial power while ferrite or grinded iron are normally used on medium to high frequencies audio, AM, FM, VHF. No core (air core) is used at Ultra High Frequencies UHF.
Good Answers: 25
07/27/2009 9:41 PM
Guest,
Fewer turns of thicker wire for a primary on a core designed for 50 or 60 Hz would be for a low Voltage AC input. If your other winding was lots of fine wire of many turns you should have used that for primary.
If the core was ferrite you could used a higher voltage at a much higher frequency or dc pulses to transfer power to the secondary.
It would be good for you to know how much current can be applied to a certain size wire of a chosen length.
Also you NEED to get a Fused Variable Autotransformer. (Also know as a Variac)
In the old days we made transformers from a bundle of shellacked nails and wires from old radio transformers.
Little motors from magnets thumbtacks wire and bent paperclips and wooden dowels and straightpins and a drycell battery. And some using electromagnets.
Made rectifiers by putting a piece of foil on a lightbulb and coating it with a few coats of parafin and using a Model T Buzzbox connected to the foil and lamp base polarized so the spark would jump to the foil to burn holes in the glass for the electrons to pass from the filament to foil when the light was energized enough to produce thermionic emission to rectify AC for our dc projects.
We studied the situation to prevent disappoinment and waste of our hard to find materials.
Jon
Reply to Forum Thread 17 comments
Anonymous Poster (1); DONBETO (1); Ed Weldon (1); Electronic Wiz (2); Joe Sparky (1); JohnDG (2); kudukdweller9 (1); not so smart (1); redfred (2); sb (1); TinTin (1); TVP45 (1); user-deleted-1105 (1); wareagle (1)
