Previous in Forum: MTECH MECHANICAL   Next in Forum: Does Speed Of Sound Vary With Source?
Tie-ins to Existing Welded Piping Systems
07/05/2009 12:58 PM
i have a long run of existing ss pipe with no flanges,and need to cut in ss tee.where do i indicate field welds on isometric drawing.should this also be a field fit and weld as opposed to just a field weld.Is it more practical to cut pipe at existing fitting such as elbow.
Re: Tie-ins to Existing Welded Piping Systems
07/06/2009 12:50 AM
it would be better and practically also if you consider fitting to pipe weld joint as a tie-in point.
07/06/2009 3:57 AM
Is a "clamp, gate valve and trepanning" operation out of consideration as an alternative?
07/06/2009 12:45 PM
Hot tap!
07/06/2009 1:02 PM
Good idea,but is this cost effective as opposed to welding.
07/06/2009 1:13 PM
If you are not in a hazardous operating environment/commodity, and can isolate your line, field cold cutting and welding is good to go...I work in a flammable hazardous environment, for our needs, hot-tapping is common...it can cost too much to evacuate a line, and can also disrupt the upstream and downstream manufacturing operations. But always....Safety First!
07/06/2009 4:49 PM
I appreciate your response.Obviously,fabrication of pipe spools is more cost effective if you have flanged connections in system.Again,I appreciate your input.
Register to Reply 6 comments
Anonymous Poster (2); munneykhan (1); PWSlack (1); steve moraga csi (2)
