Previous in Forum: Normal MCCBs vs. Current-Limiting MCCBs   Next in Forum: Undervoltage Motor Performance
220V/60Hz vs 250V/50Hz
07/06/2009 1:25 PM
I just moved to a new site which uses 220/60 from a site which 250/50 is the normal electrical current. I am having difficulty locating a tranformer to remedy the issue. I am not worried with "normal" appliances (tea kettle and coffee pot) other than possible fire haz, but for electronics not equiped with their own (Wiggits) t-former box I am very much worried. The local "electric company" tells me nothing will happen.....I am not willing to accept this at this time. Can anyone provide clues for me?
Re: 220V/60Hz vs 250V/50Hz
07/06/2009 1:42 PM
Go to the box on the right of this screen marked, "Search this Forum" and type in 50/60 hertz.
07/07/2009 10:29 AM
The point of having a searchable forum is that people should search here for already discussed topics first. If the OP had done this and then explained what clarification he needed, people here will gladly help.
07/06/2009 9:01 PM
220v/60hz and 250v/50hz, what the different?. You can use it both voltage without any problem. Even down here, most of the equipment are rated at 220V/50hz but the actual voltage are 240V/ 50 to 55 hz and the equipment are still working properly without any problem.
You may face some of your rotating tools such as motors or hand drill, the speed may be a reduce slightly than in 60hz voltage.
07/07/2009 4:09 AM
You have nothing to worry about with regard to equipment being damaged. If you were moving from 220/60 to 250/50, then with 220/60 equipment then you would probably lose any transformer due to overheating on the lower frequency. I know from experience having used USA manufactured transformers on the UK power supply.
The only difference in performance that you will get is with heating appliances where the power output is proportional to the voltage squared. The power output on 220 volts is 77% of the power on 250 volts (assuming that the supplies are actually on the nominal value).
Best wishes
Adrian Shiner
Register to Reply 4 comments
Anonymous Poster (2); lyn (1); redfred (1)
